I need a bit of help with a question I have about Ferric Chloride.
I have sharpening stones made from a Copper Brass mixture that has Diamonds threw out the stone and over time the Diamonds wear down and you need to soak the stone in Ferric Chloride from what I was told for a little bit until more diamonds are exposed and that is how you refresh the sharpening stones.
My problem is these stones were made for people who make molds and you just use them by hand scrubbing the stone on whatever you need to remove material,I use these on a knife sharpening system that use's what's often called Edge Pro format stones where the stone are mounted to an Aluminum blank with a 45 degree cut at each edge of the Aluminum blank.
My problem is however the Ferric Chloride will eat the Aluminum blank and also one made from Stainless Steel,I read a post that another member made about PVC standing up to Ferric Chloride but I do not know where to get 1/8th flat PVC.
What about Plexiglass will it attack that as well,what do you guy's recommend that I could use that would stand up to Ferric Chloride and that I can also cut with a saw to get the 45 degree cut's at each end that I need.
Look at this link if you want to see the blank's I'm talking about the stones get glued to the blanks and if 3M Super 77 Spray will not work I will use JB weld as I have used it for other water stones in the past.
