UFT12
- Mar 16, 2016
- 318
This is general question. How do you guys claculate the pressure loss through a flexible pipe supplying a sprinkler? From the manufacturer's data I see one column with the actual pipe length and one with the equivalent based on 1" S40. So assuming I have my piping system made of S40, do I need to simply add these two values or just ignore the actual length and carry only the eq. length into the calcs?
