I have made a swept, but when im done with it is turned blue and I cant make an assembly with it. If I try to put it in a assembly file, my swept disappear. somebody know whats wrong?
I think you are using the wrong function: Swept Surface; Use Swept Protrusion. But to get it visible in the ASM
- RMB on the part --> Show Hide ... --> Surfaces
Along those lines, if, in the future, you do need to make a swept surface and then have it show up in assembly, right click on the part and select "show/hide component-surfaces".
