MoyC
- Jan 24, 2020
- 1
Our contractors are welding anchor frames to pile caps based on the IFC drawings from the engineering company. There is a confusion regarding the highlighted weld symbol in the attached picture. I have heard mixed interpretations on this.
First interpretation - the all-around weld symbol with the arrow pointing to the top of the pile cap implies only top portion (3 sides) should be welded. The 4th side is an overhead weld between bottom flange of the anchor frame beam and the pile cap. The underside weld is not called out separately, so weld top 3 sides only.
Second interpretation - the all-around weld symbol with the arrow pointing to the top of the pile implies all 4 sides of to be welded. Does not matter if there is change in position of the weld or if the underside weld is not called out separately. So weld all 4 sides (3 on the top, 1 on the underside).
Which one is correct?
