Jcqa
- Jun 1, 2020
- 8
Hello, appreciate some insight on this.
For sizing chilled water pipes serving fan coil units, is there a minimum water velocity that the chilled water must have based on the flow rate and pipe size? I have searched online and I only seem to see maximum water velocity requirement instead of minimum. Is it important to ensure chilled water velocity does not drop below a certain value and are there any negative effects of a low water velocity?
