I am trying to analyze a complex structure for basic loading conditions (need not be designed for plastic strains). The model is a surface and i am using SHELL181 elements for meshing. After meshing the surface i observed that some of my shell normals are facing other way (Ansys shows the mesh with blue and purple colors). I have imported this surface from solidworks.
My question is, is it necessary to rotate these normals before applying any loads/BCs? (So that all the surface that i think is top/bottom is of same color)
If so, is there any command to rotate these normals?
I have tried the following with no success
1. Specified a coordinate system (ESYS) before meshing.
2. Tried ESURF,,reve (That works for reversing the normals on contact elements)
any suggestions would be helpful (Hope my question is clear).
NodalDOF.
NodalDOF.
