Lion06
- Nov 17, 2006
- 4,238
I am going through Design Guide #11 and I have a few questions. Does everyone perform a vibrations check for every building they do by hand or do you let something like RAM do it? In reading through the manual, it seems like so many things are left to the discretion of the designer that by the time you compare your criteria to the suggested limits in the Design Guide, it doesn't seem like it would be as reliable as, say the buckling strength of a beam. Does anyone else feel (or did you when you first started out) a little overwhelmed by this subject?
Also, where do you find vibrations info for concrete, I know it has a lot of mass and as a result, the accelerations are low and likely not a problem, but I am sure it must still be checked.
I have info for wood, although it has more to do with deflection limitations to conrol vibrations.
