weavedreamer
Automotive
Will this control the width of a rib or an groove along a basic path identified from end A to end B while ensuring the center of the rib or groove is within the prescribed tolerance zone?
An extension of principle derived from illustration shown in ASME Y14.5-2009 Fig. 7-29.
The datums, while not shown, have A as if the plane of the view is resting on it, while B and C are two holes perpendicular to A.
The position anywhere along the rib to be the feature of size taken perpendicularly normal to the centerline at any point along it.
Same question, different example.
