justAnEngineer95
Hi everyone,
If you have any experience with using automatic stabilization I would like you help with clarifying something.
Is it possible to fix the damping factor used? I have noticed that the it is still possible for it to increase during each increment, which causes the dissipated energy to exceed 5% of the total strain energy in the model as the simulation goes on until it ultimately converges.
This was the behavior I expected from "specify dissipated energy fraction" as I have encountered here that the ratio may adjust itself, but not from "specify damping factor", where I expected that the damping factor would remain constant.
I have turned off the "use adaptive stablization with max ratio of strain energy" as I discovered that this was only a target value that still could get exceeded if Abaqus deemed it necessary.
Is it possible in Abaqus to cap the damping factor?
BR.
BR.
