Quick Access Toolbar Missing - How to bring it back?
waskillywabbit
302
Got a new computer and loaded AutoCAD 2009 and now the "Quick Access Toolbar" is missing and I cannot find a place to turn it on or bring it back. I'm sure it is something simple. The "Quick Access Toolbar" is supposed to be right next to the big red "A" on the upper left of the screen. Buttons that you use often such as "save" and "print". There is a whole default list. I don't want to edit or add anything, just get the defaults there to save a few steps and so I don't have to use the pulldown menu big red "A".
Thanks.
Try typing in "menubar" in the command line. Don't put the paranthesis around it though. Change the {0} to a 1. Hopefully that will do the trick.
If its the toolbar itself that your missing. Right click off the the side in open space and select your ACAD toolbars menu and check "Standard" if that doesnt work you'll need to go through a whole list of steps in your customize workspace.
Menubar is just that...the menubar...I am talking about the quick access toolbar that goes above the menubar.
Thanks for the comments
