Quick and effective repair methods for damaged dry gas seal housing without removing the casing.
204
What is the quick and effective repair methods for damaged dry gas seal housing without removing the casing and send it back to the factory /workshop ?
I am not aware of any repair method for this damage. Review the seal drawing and determine the effect of the damage. I assume an o-ring crosses this damaged area. What will leak across that o-ring? There is a chance that slight leakage will not be a problem. Often o-rings are redundant.
Johnny Pellin
The gas migrates into the lube oil system and accumulates in the tank, causing explosion risk.
A single o-ring leak would allow process gas to go directly to the lube oil tank? That seems like some poor design decisions were made. We would normally have a separation seal with air or nitrogen directing any leakage to a vent at an elevated location. I could make more useful comments if you posted the seal cross-sectional drawing with a note where the housing damage is located.
Johnny Pellin
