LupusLupis
Hope somebody can help me to fix a problem, I got request to supply a QOC "bandlock type" size 40" to be tested to 600bar ASME VIII D.1 UG35 design and U stamped.
Every time i try to calculate it with FEM analysis it shows that in critical sections VON MISES stress it's about 3 or 4 times the ASME maximum allowable stress (I use ASTM A105 or equivalent for HUB, DOOR and SEGMENT with allowable <20000psi), is it possible to use A694F65/70 with a different allowable stress=0.8*Yield taking in consideration that it's in needed the U stamp?
Thank you for help
Thank you for help
