clh7837
Nuclear
- Feb 17, 2015
- 5
I have a vehivle that I want to weigh.
I pick the front end off of the ground and get a weight from the hoist.
I do the same with the back end of the vehicle.
I measure from centerline of each axle to the pick up point and the wheel base.
Does it make sense to sum forces and moments to get the weight that is on each axle? Then adding the weight on the two axles will giv me my weight?
Thanks, this is just kind of messing with me.
