Hello all,
I have a drawing with multiple sheets showing info about different product variants in each sheet. Each 3D assembly has about 20-25 JT parts. While i update the drawing(after loading JT in exact) and try to save the drawing, I get "failed to save part. error:580134"
From what I read in earlier posts, the only proper resolution is to raise a ticket with the GTAC and we have done the same.
As a temporary work-around, will there be any issues if I do not load the JT parts in exact while updating the drawing?
I found that I do not get any error if I do not load the JT parts in exact. Yes, I do notice that the JT are not visible in the drawing views now. Considering they are minor parts and can be temporarily ignored, will this cause any problems in future once a resolution is found?
Or is there any other temporary work around?
I am using NX 12.0.2.9
Thank you.
Thank you.
