I was wondering if anyone has a method to reduce the "fishmouthing" at the corner joint of 2 thermally insulated precast concrete walls. I'm consulting on an industrial building, built early 2000's. The shop drawings have a corner angle on the inside of the joint to prevent lateral movement.
In reality, there is no such angle. Resulting in a 3-4" wide opening at the joint. (see attached)
The building owner is worried about further movement, and I'd like to reduce the opening by jacking it back somehow, using the internal corner column, but i'm worried about causing further cracking if the panel isnt as ductile as I was hoping.
Any advice would be appreciated?
Darius
Darius
