Bowing basement wall 1
anthon89
4
Hi everyone,
I have a basement wall that is bowing, and I’m exploring different methods to reinforce it. I've attached pictures of the wall in question for reference.
The wall is about 10m wide and 2m tall.
Current Considerations:​
I’m leaning towards using carbon fiber strips as they seem to be the most cost-effective option. Here's a video summarizing various reinforcement methods, including carbon fiber strips:
YouTube Video: Basement Wall Reinforcement
Alternative Idea:​
Would it be feasible to cast a new concrete wall, approximately 100-150 mm thick, with centrally placed rebar? My thought is to connect this new wall to the existing foundation and floor joists, potentially using shear studs to tie it into the existing wall.
Since the basement is only used for storage, losing a small amount of space is not an issue.
Wall Realignment Option:​
If I want to straighten the wall before reinforcement, I assume I would need a ground anchor system.
However, this seems like a costly alternative.
I’d appreciate any advice or insights regarding:
  1. The effectiveness of carbon fiber strips for my situation.
  2. The feasibility and structural integrity of adding a 100 mm thick concrete wall as reinforcement.
  3. Whether straightening the wall first is necessary, and if so, recommendations for cost-effective solutions.
Thanks in advance for your input!
oh my, as a long time composites expert (aerospace) this scares the **** out of me. there are a LOT of things that can go wrong with composites design and install.
I have seen them installed without even removing the paint from the CMU wall. They were peeling off like sunburned skin.
I describe the bad CF installs like when your kid gets a new toy and it has those annoying stickers, but they want to put them on themselves.
Wrong spot, not straight, big bubble on the middle.
Hi again, thanks for all the responses. I measured from the middle of the wall and up. 7cm buckling….
By the way, the material is some form of concrete, with large stones. Not mortar. The lines you see are from the boards when casting.
The weird thing is that it seems like the wall keeps on bowing all the way to the slab. How the hell can the wall have moved at the base when it is anchored to the slab?
It would be hard to excavate because we have a deck on that side of the house.
Don’t really know what to do from here
I was thinking of a way to push back the wall without removing the soil from the outside and then reinforce with steel beams or something else
that sounds very risky even if it could work, which is not likely; seems you would have to react the push load against the opposite basement wall. and if you could somehow push the wall straight you have to then install the supporting beams (anchored somewhere / somehow) while the support is still in place.
