"new" roll/sway bar concept
Morning all,
referring to magazine Race car Engineering V9n1 Jan/Feb 1999 page 76 would anyone care to make comment or does anyone know if this layout has gone anywere, I cannot see any advantages and I do not understand the statement "fully floating spring damper unit". I was approached recently about this concept and recall reading it albeit 15 years ago, have reread but it still does not make sense to me apart from the fact that I would not like to do the "calcs" to determine the value of the
'spring/resistance" to bending, don,t know what to call it! Comments etc greatly appreciated.
Golfpin
That bar is gonna break at the bend. It's only a matter of time.
A regular antiroll bar distributes the deflection across its entire length. That one concentrates it at the bend.
I don't see why one would do this instead of doing it the normal, proven way.
In exotic applications (F1), sure, you could put a coil-over damper between the left and right sides and have both spring-rate and damping-rate applied to roll. That's assuming you want the vehicle to have greater roll stiffness than vertical stiffness. I seem to recall those cars having very little ground clearance in the interest of aerodynamics, and that would suggest if anything, having it the other way around ...
Here's the typical f1 3rd spring/damper arrangement which gives you full vontrol over roll as a dof, that is the 3rd spring can be replaced by any combination of travel limiters, springs, dampers and inerters.
Cheers
Greg Locock
If that site doesn't allow deep linking then
and scroll down. There's an animation as well.
Cheers
Greg Locock
Been off line for nearly a month trying to get a PC repaired !!!! need I say more.
Greg thanks for that great schematic [am still trying to fathom out how it works] it is very similar to the layout that I saw on a Pilbeam LM car that was out here a while back could not get close enough to try and see how it worked. Had a brief word with Mike Pilbeam [he was incredibly accomodating] he tried to explain the concept but he was very busy and the noise!!!!!!!!!!!
Golfpin
