USAeng
- Jun 6, 2010
- 419
We have installed a pressure regulating valve from ARI in our thermal fluid system. The point was to reduce the pressure in a secondary heating loop to about 70 PSI to keep a relief valve from opening downstream that is set at 85PSI. There is a centrifugal pump after the ARI valve with a check valve after that prior to returning to the primary loop.
We tested the system today with both the primary loop pump and secondary loop pumps running. The Primary pump produced about 120 psi on the inlet of the ARI valve. A gage after the ARI valve read 60 PSI which was great.
Problem came after we shut off the secondary pump and left the primary pump running which still showed 120PSI at the inlet of the ARI. However after the ARI valve gage now shows 85-100 fluctuating alerting us that the relief valve was opening spewing oil out into our vent tank. Luckily we caught this before there was any mess but I am trying to understand what happened. I have attached a diagram of the pressure regulating valve
