jheidt2543
- Sep 23, 2001
- 1,469
I am looking at an existing metal building with a 3'-6" deep steel truss clear spanning 64'. The top and bottom chords of the truss frame into the flange of vertical columns (not tapered)at each end. However, the bottom cord connection has a "rubber" pad shim between the column flange and the truss cord connection plate (this is not the case at the top cord, the connection is steel to steel) I do know the buildings manufacturer and will contact them to get a response.
Has anyone seen this type of connection before and what is the purpose of the "rubber" shim?
