LeonhardEuler
- Jun 19, 2017
- 200
For this project a cantilevered structure is being put in to an existing building. New beams are being placed inside of existing columns. The beams will see some torsion and thus I would like to make them closed HSS, or a W-shape with plates welded to either side to close them up, which is much more fabrication.
My first attempt is to go with the HSS so I am trying to find the best way to connect the HSS to a W-shape column. The best case scenario is that I find a connection that has been used before and has some design guidance/design examples. My proposed connection is as follows. Does anybody have any better ideas in this situation?
