Rack and pinion regeneration position
daveykbelgium
73
I have made an assembly of a rack and pinion. I have added a servo to the pinion, and can also drag the rack. I can run my analysis okay – all appears to be okay up until……
…..when I return to standard Pro/ENGINEER, I want the assembly to return to a controlled position – this would be done by using the regeneration command.
My question is how should I place the rack part into my assembly to be able to use a joint-axis setting that can control the regeneration position? The pinion isn’t an issue, as this uses a pin connection, and this worked until I tried to add a joint-axis setting for the rack.
I don’t think that I can use a slider connection for the rack, as the only joint axis settings here are for rotation, and this doesn’t apply. Presently I use two planar connections.
I think that Pro/MECHANISM is a very good product in concept, but I have really struggled with issues related to “controlled position” in the past too – am I the only person struggling with this, or is this functionality not required by other designers? Any rotational constraints are easy to make, but axial ones seem to be a real pain and a lot of trial and error.
PTC advised me not to use Pro/MECHANISM within top-down design methodologies too when I contacted them with regard to a similar problem – this was despite an article on their website last year giving details to the contrary. Strangely enough, the article is no longer available!
Thanks in advance
Dave
I'm sort of confused...
Why won't the slider connection work? You should be able to set planar references and then indicate a regeneration position in the Joint Axis settings. Unless I've missed something...
Dave,
You can always add a 6DOF joint (redundant) and set the joint axis settings for the regeneration position. This will have no effect on the Mechanism mode analysis. It will work similar to a snapshot.
I use Mechanisms all the time in a TDD context. We create a mechanism skeleton (assembly) to achieve this.
Best regards,
Matthew Ian Loew
