Radial Magnetic Coupling
Praneshsb
Hi ,
Can anybody help me to find the torque in Radial Magnetic Coupling?
Pranesh S B
Do you mean other than to measure it?
There are a number of numerical methods that get you close.
As long as the back steel is not saturated it is fairly easy to model.
Hi Praneshsb,
Do you mean the mathematical modelling of Radial Magnetic Coupling?
I have seen a synchronous Axial Coupling though (see image below). I am not sure if the radial one can be modelled the same way.
I tried numerical modeling using ANSYS. Seems like the results are wrong. I have a doubt on my B-H curve.
flofelis:- What you have given is axial coupling.
