Refaatfaraj
- Feb 25, 2012
- 61
Hi all
The attached capture is shown my structure which have a basement under the part of it and the raft foundation slab (lower foundation) is considered as foundation system for this part while as the other part of structure is supported by raft foundation (upper foundation) in different level and this foundation is rested on the soil and there is no connection with the basement walls.
My inquiry is :
Should I do a vertical joint in the superstructure at the encounter location of the upper foundation with basement walls ? ( Please take a look to the attached capture )
Knowing that the primary geotechnical investigation is referred to that the soil in different level have the same properties and the allowable bearing capacity is about 350 KN/m2 .
Thanks in advance.
Refaat
My inquiry is :
Thanks in advance.
Refaat
