p6g2p6
- Jul 28, 2021
- 37
Are lugged valves available in raised or flat face? It seems that every lugged butterfly valve that I come across has a flat retainer ring, but then the lugs are offset, such that the lugs would not come in contact with the flange when they are bolted together. This to me seems that it would be considered as raised face, since the clamping force would only be applied at the sealing face. Do lugged valves exist where the lugs come in contact with the flange, thus creating a clamping force that is distributed across the whole bolt circle diameter?
Thanks.
Thanks.
