Random errors - save to PDF
rbpmc
60
I've done search and didn't come across any similar issues. I occasionally get errors using Save to PDF. Most of the issues involve certain views of the drawing being omitted. On one occasion I got a gross error where the section views located in completely different areas of the drawing. In another occasion the main drawing view ( in which other section views were pulled from ) didn't show at all ( only the dimensions )...but the section views were fine. These drawings usually involved sweeps if that's clue to anyone. One was a swept spring with lots of geometry behind it. Another one involved a tapered helical sweep. Another aspect might have involved having a part sketch being shown such as a construction line being used for a reference. One seemed to correct itself after a video card driver update. We use PDF format for our Doc Control and I don't always catch the errors...it's been a little embarrassing at times. Using Solidworks 2010 (SP5 )basic core version.
We had this on some drawings that were issued to a customer...
1. what program are you using to convert to pdf? We've had success with 'cute pdf' but not others.
2. We also found that the person doing the pdf'ing was doing it at lightning speed - literally, openhitctrl+penterclose (that's typed as if it was done fast ;) ) and things weren't being properly generated before the print.
Hope this helps.
Tommy.
I doing this directly through Solidworks " Save as PDF " dialogue. I've never used a 3rd party software for this, not really sure how to work through a 3rd party software. It's one of those things that works generally quite well... until it doesn't and you've sent off bad drawings to a customer.
The program Tommy has suggested is free to install and works like you printing out the document. It just converts the document into PDF.
Deepak Gupta
SW 2010 SP4.0 & 2011 SP1.0
DriveWorks Pro 7 SP5
Boxer's SolidWorks™ Blog
Save as... PDF is less stable and Printing to PDF. What I've noticed is similar to above, being if you are moving too fast for the software, the PDF save as driver will skip stuff. I've particular noticed this when moving between programs while the Save As function is saving.
I recommend using Print to PDF. You'll need a printer driver, such as CutePDF also mentioned above, unless you have Adobe Acrobat Standard (or above) installed on your system.
However, Printing is not perfect either. ALWAYS check your PDF before commiting to use it.
Matt Lorono, CSWP
Lorono's SolidWorks Resources & SolidWorks Legion
Follow me on Twitter
I recommend using Matt's Print to PDF as well. I can't live without it! lol!
Actually, I use it so much I have it in my toolbar using the Customize macro Button. See attached
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2010 SP 5.0
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
 http://files.engineering.com/getfile.aspx?folder=812e2e36-e99d-478d-a582-a9a4abfe9b00&file=save_as_pdf.jpg
I highly recommend "PDF Creator"
It works like a printer, and I have never had an issue with it. It is also covered under the GNU Public License (free forever!)
Devon Murray, EIT [Mechanical]
Solidworks 2011 SP 2.0
does this work with windows 7?
Mechanical Designer
Dell T5500 XP Pro SP 3 (32-bit)
Xeon CPU 2.53 GHz 3.00 GB of RAM
nVida Quadro 4000 2 GB
Much appreciation to all. I will try and get it approved by IT to install.
