random numbers
pplrose
Computer
I would like to make a string or array of numbers, have them be random and not repeated. What would be the best way to do this?
Most languages have a random number function. Why not use that?
I'm sorry, the random number was for c++
I have a random lotto number generator I created a few years ago, written in Borland.
I'm a bit rusty on C++ at the moment but I can pull it out and get back to you if you wish.
rand() is pretty decent for generating a uniform random number.
As for the not repeated part, I suggest using the STL class set<>.
star drifter that would be great thanks
rand() is the c function that will generate your random numbers; simply include <stdlib.h>, seed your generator with srand(12345), and successive calls to rand() will return an integer in the range [0,RAND_MAX]. To scale that back to the range you want (e.g. if you want numbers between 1-100) you normalize, scale, and translate, e.g.
ValueOneToHundred = ((double)rand() / RAND_MAX) * 99 + 1; // returns random integer between 1 and 100
Making sure you don't repeat numbers is a little more tricky. A simple way would be to check for each new number whether you've used it before, but that is slow.
Better solution for your problem might be filling your array in order, then doing a random sort operation on it. A simple one would be:
1) fill array with 100 sequential numbers, 1-100
2) pick two indices at random and swap the values
3) repeat until you feel satisfied
Result: &quot;random&quot; list of non-repeating numbers, 1-100
Hope that helps,
/m
Here's a few functions you might like to try:
static const int A = 14287;
static const int M = 3676253437;
static const int Q = M / A;
static const int R = M % A;
// Construct with Value for the state.
Random::Random( int Value )
if( Value < 0 )
Value = Value * (-1);
state = Value;
if( state == 0 )
state = 1;
// Return a pseudorandom int, and change the
// internal state.
int Random::randomInt( )
int tmpState = A * ( state % Q ) - R * ( state / Q );
if( tmpState >= 0 )
state = tmpState;
else
state = tmpState + M;
return state;
// Return a pseudorandom double in the open range 0..1
// and change the internal state.
double Random::random0_1( )
return (double) randomInt( ) / M;
// Return an int in the closed range [low,high], and
// change the internal state.
int Random::randomInt( int low, int high )
double partitionSize = (double) M / ( high - low + 1 );
return (int) ( randomInt( ) / partitionSize ) + low;
Have fun!
Derrick
