Rapid Vacuum furnace/fluidized bed HT in Uk
rosshenrys
Materials
May 19, 2009
Hi there, I am trying to Heat Treat a Nickel based super alloy but the damn thing keeps cracking. We produce our parts using a DMLS (direct metal laser sintering) machine on top of a 36mm tool steel plate. We have to stress relieve the parts before they can be cut off the base plate, as such there is a massive heat sink attached to the parts (see pic), the whole part weighs in at 4.5kg. We think the problem of cracking is occuring on the way up, a detrimental phase is precipitating out between 800-900oC.
Does anyone know of a Heat treater that can ramp they furnaces up at speeds greater than 31oc/min to 1180oC?
Also I've seen that Fulidized bed Heat treatments could be a way forward, anyone know of one in the UK that will go upto 1180?
Cheers for your help
Ross
Yep, Bodycote are being very unhelpful, plus they have said they can't meet the specification of the HT
