RBE interface force 1
FSB1
Aerospace
Sep 23, 2013
71
How to evaluate the forces at RBE2 and RBE3 interfaces?
Is it possible to do it without a spring or beam element in between?
What I have is
CQUAD4 - RBE2 - CQUAD4
and
CQUAD4 - RBE3
SWComposites, how do you use to do that?
I'm using femap and the nodal output options I have are
Applied load
Constraint force
Equation force
Force Balance
Which one correspond to your suggestion?
Dear FSB1,
The best way to get interface loads beteween any type of elements is to use the FREEBODY Diagrams in FEMAP, making sure to activate the FORCE BALANCE in the NASTRAN Ouput Request:
The following image is an example of the FREEBODY diagram feature of FEMAP extracting loads between RBE2 and 2-D Shell CQUAD4 elements:
The same example problem using RBE3 elements:
In the FREEBODY Diagram creation in FEMAP make sure to use the option INTERFACE LOAD:
To learn more about RBE2/RBE3 elements with FEMAP please visit my blog in the following address:
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48004 BILBAO (SPAIN)
WEB: Blog de FEMAP & NX Nastran:
Nice!
Thank you Mr. Blas
