mesapol
- Feb 16, 2005
- 5
How can I determine the N.A (neutral axis)of a rectanular column with bars in all 4 faces? It is different from beam, I cannot set C = T to evaluate the N.A, there is axial force, unlike beam? In addition, since there is axial force n bending, do I just refer to N.A or the plastic centroid still play a role? I am confused. I thought I only consider plastic centroid when the section is in uniform compression.
Thank you for your help!
