RC load
zolka
Automotive
Jul 8, 2008
29
I have a very simple question! What is the output voltage of a series RC load? Suppose the Vin is AC!
Here is the picture!(attached)
It can be solved using a simple voltage divider based on the impedances.
Is this a homework question?
No, this is not a homework! I have to connect R, RL, RC, RLC loads to an induction generator! R and RL works fine, you can see the voltage drop at the IG terminals, but RC and RLC are giving me hard time. In the first two cases the dif. equation is described by currents. But at RC and RLC voltages are involved in the dif. equation, and I will have to make changes! I hope I can cope with it! Otherwise, you will hear about me soon!-))))))))[thumbsup2]
Let's say it this way:
Zr = R
Zc = 1/(I*2*pi*f*C)
Zload = ? (you didn't tell us).
Zcparaload = Zc*Zload/(Zc+Zload)
(Zcparaload is Zc in parallel with Zload)
Voltage divider:
Vout=Vin*Zcparload/(Zr+Zcparaload)
where complex (vector) arithmetic is used, sinusoidal steady state is assumed
If Zload =0, then
Vout=Vin*Zc/(Zr+Zc)
|Vout|=|Vin|* |Zc|/sqrt(R^2+|Zc|^2)
where |Zc| = 1/(2*pi*f*c)
