Re-entrant Corner. Do both the projections need to be>15% of the corresponding dimensions? 3
NewbieInSE
BD
Dear Engineers,
I hope you all are fine.
Please refer to the following figure.
I have read the following and compiled some texts from the books of Taranath.
Again elsewhere I found this, where it says "or" (either of them, i understood)
What ticks in my mind is, both the projections need to be greater than 15% of the correspponding plan dimensions, otherwise it won't form a cruciform large enough to concentrate stress. But I couldn't come to a conclusion on this.
Please share your understanding of the matter.
Refer to Table 12.3-1 Horizontal Structural Irregularities , a reentrant corner irregularity occurs when both
plan projections beyond the corner are greater than 15% of the length of the plan dimension in the direction of the projection.
Copy and paste of the clause :
Reentrant Corner Irregularity: Reentrant corner irregularity is defined to exist where both plan projections of the structure beyond a reentrant corner are greater than 15% of the plan dimension of the structure in the given direction.
From all my sources and references, ASCE, the SEAOC Manual, etc...BOTH projects need to be greater than 15% for the irregularity to exist.
Thanks a lot HTURKAK and LockeBT.
Not if they are two separate buildings. I'm not aware of the 15%; I'm not sure it makes sense. If you have a 'significant' change in the building envelope, without defining what significant is, you can have some issues in your building envelope. As soon as you have a transition, it's a matter of closely looking at it to confirm it there is a possible problem.
