glulambeam
- Oct 20, 2016
- 18
thread404-275179
referring to this earlier thread:
Don't the threads on the insert take any amount of the external load?
I've been usually adding the preload + the full amount of external load to check and see if the parent material the insert is installed into, doesn't shear out, but this conservative approach naturally doesn't work if the external load is large. Is it just the case that the insert sees whatever load that the bolt sees? The bolt is typically calculated as carrying the preload plus some percentage of the external load (I usually just top it off at 33%, though I've heard that the theoretical limit is 25%).
