Re-submitted Abaqus job and output has dissapeared
artm684
1
I run a static simulation and got the results I needed. I then used 'save as' to run multiple versions of the same model with slightly different parameters (making sure to save them in separate folders).
For some reason when I tried to re-submit my initial job, it runs straight away and the visualisation becomes available immediately.. but with no output data (i.e the model is completely blue and no stresses are visible in 'Visualisation). I'm confused because I did not change any parameters in any of the modules and it was working perfectly before
Does anybody know what could cause this? I have recreated the job and it hasn't worked also
What is the status of this re-submitted job ? Was it completed ? You can check sta, msg and dat files to see if it was solved successfully.
Also restart A/CAE. Maybe you've set fixed limits in the legend that don't fit to the new result.
