Reaction-Diffusion Equations and Matlab
GeoTux
Marine/Ocean
RO
I want to solve the reaction-diffusion problem, in 2D, with Matlab:
Sum_{j=1}^{4} D_{1j} * (drond^{2}z_{j} / drond x^{2} + drond^{2}z_{j} / drond y^{2}) + R_{1} = 0
Sum_{j=1}^{4} D_{2j} * (drond^{2}z_{j} / drond x^{2} + drond^{2}z_{j} / drond y^{2}) + R_{2} = 0
Sum_{j=1}^{4} D_{3j} * (drond^{2}z_{j} / drond x^{2} + drond^{2}z_{j} / drond y^{2}) + R_{3} = 0
Sum_{j=1}^{4} D_{4j} * (drond^{2}z_{j} / drond x^{2} + drond^{2}z_{j} / drond y^{2}) + R_{4} = 0
Boundary conditions: x = 0,1 z_{1} = 1 ; x = 0,1 z_{2,3,4} = 0
So, I have a system with four partial diffrential equations. and I want to plot the solution for every equations.
What it's wrong in my code ? The plots of solutions must be a surface (almost like a bell), but is not.
Code:
clc;
clear;
close all;
   a=0;b=1;n=5;
   h = (b-a)/(n+1); % step
   I=eye((n-1)*(n-1));
   A11=zeros((n-1)*(n-1));A12=zeros((n-1)*(n-1));A13=zeros((n-1)*(n-1));   A14=zeros((n-1)*(n-1));
   A21=zeros((n-1)*(n-1));A22=zeros((n-1)*(n-1));A23=zeros((n-1)*(n-1));A24=zeros((n-1)*(n-1));
   A31=zeros((n-1)*(n-1));A32=zeros((n-1)*(n-1));A33=zeros((n-1)*(n-1));A34=zeros((n-1)*(n-1));
   A41=zeros((n-1)*(n-1));A42=zeros((n-1)*(n-1));A43=zeros((n-1)*(n-1));A44=zeros((n-1)*(n-1));
   b1=zeros((n-1)*(n-1),1);b2=zeros((n-1)*(n-1),1);b3=zeros((n-1)*(n-1),1);b4=zeros((n-1)*(n-1),1);
   k1=1;k2=0.4;k3=0.5;k4=0.2;k5=0.1;
   % diffusion matrix
   D11=1; D12=-0.43; D13=-0.19; D14=-0.265;
   D21=-0.14; D22=1.475; D23=-0.025; D24=0.235;
   D31=0.105; D32=0.07; D33=1.475; D34=-0.19;
   D41=-0.085; D42=-0.245; D43=0.27; D44=1.17;
   [x,y] = meshgrid(a:h:b);      % uniform mesh
   % Matrix A
   K1D = spdiags(ones(n,1)*[-1 2 -1],-1:1,n-1,n-1);
   I1D = speye(size(K1D));
   Delta = kron(K1D,I1D)+kron(I1D,K1D);
   % A1i
   A11=D11*Delta-(k1+k3)*I*h^2;
   A12=D12*Delta;
   A13=D13*Delta;
   A14=D14*Delta-k5*I*h^2;
   %A2i
   A21=D21*Delta-k1*I*h^2;
   A22=D22*Delta+k2*I*h^2;
   A23=D23*Delta-k4*I*h^2;
   A24=D24*Delta;
   %A3i
   A31=D31*Delta;
   A32=D32*Delta-k2*I*h^2;
   A33=D33*Delta+k4*I*h^2;
   A34=D34*Delta;
   %A4i
   A41=D41*Delta-k3*I*h^2;
   A42=D42*Delta;
   A43=D43*Delta;
   A44=D44*Delta+k5*I*h^2;
   % b
   b1(1)=(-1/h^2)*D11;
   b2(1)=(-1/h^2)*D21;
   b3(1)=(-1/h^2)*D31;
   b4(1)=(-1/h^2)*D41;
   b1(n-1)=(-1/h^2)*D11;
   b2(n-1)=(-1/h^2)*D21;
   b3(n-1)=(-1/h^2)*D31;
   b4(n-1)=(-1/h^2)*D41;
   % aprox solution
   A=[A11 A12 A13 A14;A21 A22 A23 A24;A31 A32 A33 A34;A41 A42 A43 A44];
   bn=[b1;b2;b3;b4];
   ub=reshape(bn,(n-1)*(n-1)*4,1);
   v=inv(A)*ub;
   % split the solution vector
   pas=size(A11);
   v1=v(1:n+2);
   v2=v(pas+1:2*pas);
   v3=v(2*pas+1:3*pas);
   v4=v(3*pas+1:4*pas);
   vv1=zeros(n+2,n+2);
   vv2=zeros(n+2,n+2);
   vv3=zeros(n+2,n+2);
   vv4=zeros(n+2,n+2);
   % boundary conditions
   vv1=[ones(n+2,1) v1 ones(n+2,1) ones(n+2,1) ones(n+2,1) ones(n+2,1) ones(n+2,1)];
   vv1=[zeros(n+2,1) v1 zeros(n+2,1) zeros(n+2,1) zeros(n+2,1) zeros(n+2,1) zeros(n+2,1)];
   % plot
   figure
   set(gcf,'DefaultAxesFontSize',8,'PaperPosition', [0 0 3.5 3.5])
   subplot(2,2,1);
   surf(x,y,vv1);
   title('Numerical solution for Ecuation1');
   subplot(2,2,2);
   surf(x,y,vv2);
   title('Numerical solution for Ecuation2');
   subplot(2,2,3);
   surf(x,y,vv3)
   title('Numerical solution for Ecuation3');
   subplot(2,2,4);
   surf(x,y,vv4);
   title('Numerical solution for Ecuation4');
makes no sense to me, and you don't seem to do anything much with vv2 etc
Cheers
Greg Locock
Hi Greg,
Thanks for your reply.
I think my issues start when I try to split the big vector v, into 4 small vectors (one for each equation:v1,v2,v3,v4).
After that, the boundary conditions(vv1,vv2,vv3,vv4) is not correctly implemented (it's need to be created dynamically).
In conclusion, there is a size issue between:
- [x,y] = meshgrid(a:h:b);
- split the vector v
- surf(x,y,vv1);
But, I don't have any idea to resolv the issue.
Cheers,
George Sarbu
Frankly I'm amazed it runs at all
v2=v(pas+1:2*pas);
pas is a 1x2 matrix, what do you think that line is supposed to accomplish? I suspect that you really want
v2=v(pas(1)+1:2*pas(1));
doubtless there are similar problems with array sizes later on
Cheers
Greg Locock
I make some changes:
Code:
pas=size(A11);
v1=v(1:pas);
v3=v(2*pas(1)+1:3*pas(1));
v4=v(3*pas(1)+1:4*pas(1));
for i=1:pas
  vv1(i,1)=1;
  vv2(i,1)=0;
  vv3(i,1)=0;
  vv4(i,1)=0;
end
vv1(:,2)=v1;
vv2(:,2)=v2;
vv3(:,2)=v3;
vv4(:,2)=v4;
for i=3:pas
  for j=1:pas
    vv1(j,i)=1;
    vv2(j,i)=0;
    vv3(j,i)=0;
    vv4(j,i)=0;
  end
end
Now, if I take h very small: h = (b-a)/(n+10), the surf function run well. But, of course the plot is not like a bell :)
Sadly I don't have the time to figure out what you are actually tying to accomplish (the first 4 lines in your first post don't actually mean anything to me) so all I can suggest is to break the problem down into small parts, check that each step works, including the sizes of the arrays, at each step.
Cheers
Greg Locock
