jkal321
- Jul 10, 2007
- 18
I feel I should know how to read a logarithmic graph but I seem to have been wrong all along and I need someone to correct me.
I am taking the PE exam in HVAC soon. I have been going over the refrigeration cycle problems in a reference book I have.
Whenever I measure the pressure of the diagram, I am always off from the answer which is approximate and close enough to the answer.
But one answer, I was way off because I read the pressure wrong or not close enough to the instructor.
As an example, I have attached a marked up chart showing the location: [ The area in between 200-400 psi ] accordingly to the graph is divided into 4 divisions but logarithmic divisions, the pressure was read by the instructor [320 psi], while I read it [350 psi] which made a big difference in the answer.
Could you please help and if there is a rule of thumb to read these value correctly vs. the linear scales.
Thank you,
Thank you,
