Recommendation of pressure/vacuum valve manufactures
ritchie888
Bioengineer
Jun 22, 2011
24
Hey all,
I need some advice and recommendations on what to search for in regards to my project.
The best way to think of my project is to think of inflating and deflating a balloon. I will have a partially inflated balloon of which I need to use a vacuum valve to suck all the air out and leave it flat, after six seconds I then need to re-inflate the balloon to the same size it was originally, and then repeat this process.
The problem I have is that I'm not sure what I should be searching for or who to get it from. I've tried searching for pressure/vacuum valves, automation and control valves, and the such, but not getting anything helpful.
I will be using a DAQ and LabVIEW to control the valves and need to know what I need to achieve this. Links and recommendations will be most appreciated.
Parker-Hannifin, SMC, Fabco-air, micro-air and about a million others.
Thank you very much for your responses, this is exactly what I need!
If anyone else has any recommendations then keep them coming!
I've been having a look at those solenoid valves and they look very promising. Does anyone else have any other valve suggestions so I can have some comparison?
I started with looking at Festo and their valves but I think it's a bit too automated (and expensive!) for my needs, you guys agree or would you say that Festo may have something to offer?
Too automated?
Open or closed.
Or common-to-A / common-to-B
Basic solenoid valves are essentially commodity items.
By 'too automated' I meant that their uses and features far exceed what I require them to do, if they do what I want at all. Plus, having found a vacuum solenoid valve for £30 they're a tenth what Festo are charging.
Maybe I missed something... I thought pumps moved fluids... Valves work as pumps now?
I think searching "vacuum" will take you down the wrong path. That will get you into the realm of Ultra High Vacuum (UHV) and into vendors like VAT, MDC, and Varian.
-Dustin
Professional Engineer
Pretty good with SolidWorks
