Mar 25, 2019 #1 ben3929 Civil/Environmental Jan 20, 2010 35 US what type of gasket is recommended to use for water pipe line? water pressure 300 PSI. spiral wound metallic gasket vs EPDM rubber gasket?
Mar 25, 2019 #2 mk3223 Mechanical Feb 4, 2006 1,476 US Any more detail of the piping info, such as material, operation condition, etc.? IMO, based on the piping material and/or flange joint type, the spiral wound gasket may go with the RF flange, as rubber gasket may be used in the FF flange. Upvote 0 Downvote
Apr 2, 2019 #3 SnazyDragon Mechanical Aug 13, 2018 15 CA 300# 304 SPIRAL WOUND LOW STRESS FLEX GRAPHITE FILLED CS OUTER RING Commonly used in industry. Check pressure-temperature ratings based on design conditions. Upvote 0 Downvote
Apr 8, 2019 #4 KevinNZ Mechanical Jun 12, 2003 827 NZ There are many 'paper' gaskets that suitable for water duty. But if there are water hammer events on your line spiral wound maybe better. Upvote 0 Downvote
