elquesifilma
Chemical
- Jun 12, 2008
- 21
We currently have production wells with ESP (Electrical Submersible Pumps).
What are the typical safety devices to protect the flowline from rupturing form overpressure?
Our flowlines are polyethylene SDR 7 which are rated at 133 psi for Crude service.
The flowlines are tied into 3 phase separator operating at 40 psi. We currently have a check valves and chokes at the casing and tubing.We have a pressure safety high sensor, that if it senses higher pressure on the line exceeding 133 psi, it shuts down the ESP.
Could someone please advise, wether shutting down the ESP is enough protection for my flowline?, or do i require a shut down valve?
Thanks in advance!!
Thanks in advance!!
