rohit307
- Jun 26, 2012
- 10
I am working on designing a Rectangular Water Storage Tank. (AWWA D-100)
I need to consider Stresses and Load combinations that include Thermal Movement due to Temperature change - *Correction - Design requirement Ambient DeltaT (Effects for Solar heat gain to Night time - sky heat Loss) For ambient temperature change from 105F to -10 F.
I am thinking i need to consider the actual effects of Heating and cooling (Conduction, Convection and Radiation Heat gain and loss) to figure out the Delta T needed for Design/ Self-Straining Force check on the Tank (steel shell and bracing)? Thoughts?
I am curious if there are procedures or guidelines for it in any code or Practice for engineering a rectangular tank. I would appreciate any inputs. If Ansys/FEA approach is the best then do share articles or information on how to approach it in the software.
Tank is 55'x9.5' and 13' height closed Rectangular Tank has a good bit of internal bracing for the standard Hydrostatic and (Wind / EQ combinations) . I am trying to figure out how to go about the thermal ?
