Reducing Leakage Current in Foil Heating Elements.
Ronin2119
I'm currently conducting IEC 60335-1 testing on a commercial appliance that utilized foil heating elements.
IEC requires that we conduct a leakage current test after humidity conditioning. I have noticed that the foil elements are absorbing enough of the moisture to cause the appliance to fail this testing. Any ideas on how to eliminate this issue
Ah - are these laminated foil heating elements? I see specifically lists moisture resistant elements as a special order.
I expect the maker of the heating element will have to be responsible for meeting the requirement.
Etched foil heaters will have a similar situation - the maker should have sufficient experience.
If the leakage is to the housing, then better insulators seem like the obvious choice - electric dryers manage to be safely made with a bare exposed nichrome heating element that is on ceramic insulators to prevent leakage.
In fact, they are the Jen-Ter foil laminated elements. We've been using these for years but have since added an embedded PEPI to the design. I will reach out to my contact a jen-ter to aid with this issue. My project is currently on hold a UL...
