White Rust in HVAC Ductwork, again
PagoMitch
71
All,
So last year I posted a question re: how to resolve white rust on interior sheet metal duct wall. That thread has been closed, but here is the link:
I recommended to the owner that the Contractor shall line the ductwork with new, un-blemished G90 sheetmetal. The owner supported us (our firm), and they completed that work on (1) of the AHU's end of last year. Fast forward several months, and the completion of this task (on the other AHU) has been a topic on our weekly task list discussion ever since. Until yesterday; when the Contractor advised that it was done. I asked them how they did it. Silence for several seconds. Then the Contractor Field Foreman (not the Project Manager, who was sitting next to him) said that one of their (the Contractor's) consultants (not an engineer, but more a Project Manager) advised that they could just paint it with spray galvanizing. So they did. I'm assuming they went to ACE hardware, bought a dozen cans of spray galvanizing, and applied over all the white rust. I was speechless. Photos from earlier thread below. I have requested the Contractor provide me with details of exactly what product they used.
White Rust 1.jpgWhite Rust 2.jpg from earlier thread for context:
So. Just to reiterate. This location is the Supply Air plenum, downstream of the final MERV 14 filters in a 30,000 CFM AHU, serving the core area of a hospital. My concern expressed in the earlier thread was that while spray galvanizing works fine - on a welded hitch or the underside of your car - I can find no references for the suitability of applying this to the inside of ductwork, let alone ductwork serving a Hospital.
My concerns are mainly:
1. Surface prep. Due to the difficulty of working within this plenum, I would hazard a guess that they just sprayed the galvanizing over the white rust. From my experience, spray galvanizing only works well when applied to bare metal. Will parts eventually flake off and be sent down the ductwork to be discharged out the Supply Air grilles into the breathable environment and deposited on horizontal surfaces? My guess would be yes, eventually. Next month? Next Year? Several years? No matter the timeline, it WILL happen; at which point the AHU will need to be turned off, apply new G90 steel, then ALSO clean the downstream ductwork to eliminate the contaminants... This would be weeks of work, at least...
2. The additional components being added to the spray-can to make it sprayable are...nasty. Will these eventually slough-off and be mixed with the airstream? My guess would also be yes. From the MSDS on an ACE Spray Galvanizing can:
Oddly enough, the MSDS on this can does not say anything about zinc purity or other compounds... ??? Not sure how that happens, but I have to assume it is close to the label at 92%...
At this point, I am waiting for them to get back to me with the exact spray galvanizing they used. Although I do not think the particulars of another brand will change the underlying problem. In my opinion, this stuff has no place inside an air duct; let alone for use inside a hospital, and downstream of the final filters. My recommendation to the owner is to require the Contractor to resolve this properly, which would entail another G90 layer of sheetmetal to cover and encapsulate this chemical soup, and prevent it from sloughing off into the downstream ductwork and entering what is supposed to be a reasonably sterile - or at least, uncontaminated-by-heavy-metals environment.
What a pita. If they push back (which I expect), my next move would be to get an industrial hygienist involved... I think.
Thoughts?
TIA.
Looks to me like those listed components will evaporate in very short order. If they can stand the smell and the amount - which is the critical part of any chemical contamination - one spray can vented into a building is unlikely to be noticed, but 50 cans might be a short term intoxication problem.
Certainly other brands may have different components, so an evaluation must depend on which one. I am surprised that a roller application wasn't used from a paint can. Less volatiles and more direct amount deposited; less need for a dust mask to avoid zinc plating the lungs of the users.
I doubt that there is sufficient airspeed to maintain any big flakes in the air supply; the biggest contribution would be due to atomization of the liquid during the spraying. I don't see what binds the material in place. It does require contact via electrical conduction to provide sacrificial protection, so I think it cannot be encapsulated.
If flaking is a worry I suppose going over it with a transparent coating would bind the zinc particles in large clumps so that only if moisture penetrated the coating that the zinc would do it's job and inspection could see if there was such a problem, unlike using an opaque paint.
Zinc-oxide, the product of protection, is generally benign, though inhaling milligrams or such as nanoparticles such as from welding galvanized material, can make people feel ill. It's used in sunscreen for external application.
Over-layering with sheet metal leaves a place for mold to grow without being detected.
Replacing the duct with clean material would be the other option.
Get the ducts replaced that is the only lasting solution. Moreover it is a healthcare facility and an air quality check may expose you to potential insurance claims. If the duct work is not very old you need to investigate what is causing this for eg saline air in a coastal area. If weather is causing it Aluminum duct work may be a better alternative
It's a fine mess.
I doubt that the applying new galvanized sheet over the existing rust would have worked. As 3DDave noted, it just becomes a place for mold to grow and other crap to accumulate.
Did whoever actually did the spraying wear any sort of respirator? Toxic nasty stuff in an enclosed space. Are there any occupational safety laws where you are?
Did you hire the contractor, or the hospital?
