Hi All,
I have a castellated beam spanning 17.2m as part of a braced steel frame. I need to remove a 2000mm wide by 400mm deep section at approximately the quarter point, please find a sketch attached. I have assessed the current loading on the beam and sized two angles to be welded on either side of the reduced section to take the current bending moment and shear loads.
Is there anything else you would be considering?
