EngDM
- Aug 10, 2021
- 633
I am being asked to design a connection to splice a channel at midspan so that they can get the channel into the space (for a reno). They are requesting bolted connections to avoid welding in a combustible space.
By adding a row of bolts to develop the full strength of the channel, I am essentially reducing the gross area in tension and compression of the channel. In compression I don't see any real issue since it will transfer thru the bolt, but the tension flange is losing quite a bit of area. Not to mention the shear lag reducing my bolts even more, and requiring more bolts.
By adding this connection it seems to me that I am reducing the capacity of the channel by a lot.
I really would prefer to do welded flanges and a shear web bolted plate.
Has anyone here dreamed up a full capacity splice for channels before? My Tf/Cf for full strength is like 365kN...
