Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
CBL to Mastercam said:I am sometimes asked by Mastercam users to re-orient a SolidWorks model about its co-ordinate system. Is it difficult to re-oreint a SolidWorks solid model in Mastercam?
Received this reply at 4:31pm
[/quote Mastercam to CBL]
Re-orienting a solid model in Mastercam is a painless function of just xform rotate. This is assuming the Mastercam user has the Solids option in their software. Without Solids they can’t manipulate the part by moving, rotating, or modifying it. I would assume that is the scenario in the cases where you are asked to re-orient the model in SolidWorks. Basically the Mastercam user must have Solids in order to move the model. If they do not have Solids they should read the model in as surfaces. They then have free reign to manipulate the model as needed.
Thank you for the very swift response.
Is the Solids option an expensive add-on or is it included in the Mastercam Direct for SolidWorks "translator" product?
The solids option is typically about a $1000 add-on but that can vary depending on products already purchased and any promotions being run. We typically use 3 or 4 different promotions a year to highlight a particular piece of the software. It is not included in the Direct translators. Some companies view this as expensive and others don’t blink an eye. I view it as a cost-effective option for customers who routinely read in solid models. We’ll have to see what your Mastercam counterpart thinks. The best option would be for them to contact their local Mastercam Reseller to get a quote on the price for them.
