controlnovice
- Jul 28, 2004
- 976
We have a PLC (Process Automation) that never has any changes, nor has it failed.
Our concern is 'if you don't use it, you loose it', in that without use, people tend to forget how to use it.
A failure of this PLC would shutdown the unit. It is the only one of its type in the plant. (Yes, not ideal, and it is in the long range plan to replace).
Our technicians have been going to the same training every two years. I'm questioning if the frequency of training is necessary. The technicians insist it is because again, if you don't use it, you loose it.
I feel with the training manuals that no refresher training should be necessary. One may forget the class, but should be able to find what is necessary in the manuals.
I think a 4 hour refresher course would be acceptable every 2 years. Or, if the concern is really that high, that self study would be sufficient.
Any ideas out there on frequency or need of refresher training?
______________________________________________________________________________
This is normally the space where people post something insightful.
