Regarding to Abaqus Inp to Python Script
Adil Memet
DE
Dear All
I have a question about from Abaqus Inp file to Python Script. the other day, I was searching the internet and found some interesting stuff, perhaps some of you made it already. my question is to if there is an easy way to modify the Abaqus Inp and change into Python Script, so that when we could run Python Script in Abaqus CAE directly for simulation. there is an example from Abaqus documentation, I would be very much appreciated if you could help me change into Python Script. Thanks in Advance.
Abaqus->
Verification
-->Analysis Procedures and Techniques
-->Additive manufacturing process simulation
-->Heat energy balance
-->Problem description
Kind Regards
 https://files.engineering.com/getfile.aspx?folder=5bdae2ce-c2e7-431f-b371-c76549f169db&file=am_heatbalance_dc3d4_concentrated.inp
Check the documentation chapter Analysis —> Analysis Techniques —> Parametric Studies —> Scripting Parametric Studies. There you will learn how to parameterize input files to run parametric studies with Python commands.
