If using literal mesh sheets I'd do something similar to the second one as it's way too much effort for them to cut the sheets to form option 1
Check the buildup thickness at the angle changes as they'll be large and you will probably fuck the cover up
If the 'mesh' is actually discrete bars then I agree with Tomfh, I'd do option 1 and tidy up the perimeter with trimmers
