Craig_H
- Jan 11, 2019
- 200
Hi all,
First off, thanks to everyone on this forum for making it a fantastic place to bounce ideas off of each other, and gain knowledge through past threads. I have searched the forum for this topic, but cannot seem to find a good discussion of the specific situation that I am currently facing. I've been lurking around eng-tips for the better part of a year, but have not been very active in posting.
I work in a region with a severe crunch on housing. This has spurred many home owners to develop their basements into additional accommodation. In concert with that comes the need for means of egress from bedrooms, and the requests for creation of window openings in existing concrete foundation walls. These walls are generally constructed with the minimum reinforcement required by Part 9 of the Alberta Building Code at the time of construction. Let's take a typical wall as being 200 mm [8"] thick, with 10M reinforcement 300 mm [12"] on-center both vertically and horizontally. As I am sure many know, there is often less than this amount of bar in the walls.
With the hand that I am often dealt, the concrete does not contain sufficient reinforcement to simply cut an opening and design the existing concrete above as a reinforced lintel/header. CSA A23.3 also does not appear to allow the use of plain concrete in this situation. Cutting up to the top of concrete and installing a wooden header is often not an attractive proposition for a suite of reasons (grade elevation, depth of basement and wanting the window low enough to climb out of, etc).
What suggested solutions does the community have for retrofitting reinforcement around window openings in plain concrete walls? I have been toying with the idea of carbon fiber reinforcement on the exterior of the wall, and would be interested in hearing field-tested feedback on how that product has turned out. Also, suggestions on how to protect the fiber from future damage would be very welcome.
Thanks all!
Thanks all!
