AlejandroFernandez
Hi, I have a issue about a reinforcement design, acording to ASME B31.8. And is on point 831.41 General REquirements... specifically on section "e" "The area of reinforcement ...is defined as a rectangle whose length shall extend a distance, d, on each side of the transverse centerline of the finished opening and whose width shall extend a distance of 2 1?2 times the header wall thickness on each side of the surface of the header wall..." Appendix F figures5
The length of this rectangle is two times internal diam. (2*d), this measure is a maximun or minimun limit?
Can i do it shorter than 2*d?
thanks
Alejandro Fernández
I+D&I
Sitelca
thanks
Alejandro Fernández
I+D&I
Sitelca
