sanford1
- Apr 2, 2013
- 1
I have an existing 25' beam consisting of (2) 1.75”x11.25” LVL engineered wood beams with a ¼” steel flitch plate sandwiched between the LVLs. The beam has a few (basically none) small carriage bolts holding it together. The beam has been in place for approx. 10 years and is starting to show signs of rotation / torsional buckling and moderate deflection. Calcs are showing that two 3/8 plates would need to be added and throughly bolted, however drilling the existing beam would be labor intensive. Widening the beam a great deal will be difficult due to an existing door and window on each side of the support column. Adding a mid-span column isn't an option.
Does anyone have any suggestions on alternative designs to tackle this problem?
